Log Cabin Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 06:41 PM   #1
Log cabin attic insulation
Hi guys,
I'm 18 and living at home, out back in a log cabin. It has only aeroboard under the floor for insulation. As you'd imagine it gets quite cold out there. Now I'm fine as I have a heater on all the time during the winter. However I plan on moving my reptiles from the house out into the attic. I'm going to need to insulate the attic first. Getting it done professionally is not really an option as funds are low.
I have barely ever put a nail into a wall before, quite literally. So please bare with me.
So first of I have decided on using 2 x 1 batten, with 25mm kingspan covered with chipboard.
Could I use plasterboard instead of chipboard ? Will 25mm kingspan be enough.
Thirdly and most importantly. I have no idea how to ventilate. I've read up about soffit vents etc. Still cant get my head around it.
My attic is similar to this, though smaller and no furniture
Any kind of help is greatly appreciated. Thanks.
anfieldoreilly is offline   Reply With Quote
Old 03-05-2012, 08:50 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
start thinking in terms of insulating the outside of the roof,which you can do and still keep the original look of the loft
Tom Struble is offline   Reply With Quote
Old 03-05-2012, 11:51 PM   #3
Rewards Points: 1,092
Exterior roof insulation is a good idea, and surely the easiest for you. Read on greenbuildingadvisor.com and/or buildingscience.com so you get the right thickness, tape the joints, etc. You'll have to dink w/ your present roofing; remove and replace it, or remove and put on new stuff.
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
