Log Blasting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 03:49 PM   #1
Log Blasting
What is the difference between a Harbor Freight media blaster (they sell walnut shells) at around $100 and the corn blasters that retail for $3500; I need to take whitewash off the inside of an old log building and it looks like the lower price media blaster will do the job. Thoughts, anyone?
nedlebeau is offline   Reply With Quote
Old 06-21-2010, 05:59 AM   #2
Rewards Points: 4,454
sandblasters from h/f work well for about 10min,,, rent a decent ( clemco, schmidt, etc ) 300# pot w/air dryer,,, for best results, place 150w outdoor light bulb under the mixing chamber.
IF you're going to do this work professionally, you'll buy the right tools,,, IF you're a h/o-diy'er, you'll be cheap & go to h/f,,, guess you're the latter as a pro would already know,,, when you rent the air compressor ( 185cfm's best ), be sure air's dry as you can get it,,, btw, 1/4" venturi nozzle works well
Old 06-21-2010, 07:36 AM   #3
DIY staff
Rewards Points: 7,174
There is a sandblasting forum on the sister site--Contractor talk. Click on the link at the bottom of this page. It's for pros --but you can learn a bit by reading.
Media blasting services might not charge as much as you think--Have you made any calls?
Corn Cob Blasting anyone? jpearson311 Painting 14 03-05-2010 10:06 PM
