Old 03-26-2008, 11:22 PM   #1
Locating posts for a patio cover
Greetings.
I am planning a patio cover over a 20' x 20' slab that is attached to my house. I will be using 4 steel posts bolted to the slab for support. My question is how do I set the posts square to the house and square to each other? The main beams are 4 x 12 cedar so I am concerned about bolting the posts down then find out I am a degree or few off and the beams won't locate properly.
thanks
roadkyng is offline   Reply With Quote
Old 03-27-2008, 09:26 AM   #2
conc repr & dec conc
Send a message via AIM to dec-conc-artisan Send a message via Yahoo to dec-conc-artisan
6-8-10 triangle,,, this is 9th grade geometry &, yes, i slept thru it too ! ! !
dec-conc-artisan is offline   Reply With Quote
Old 03-27-2008, 09:56 AM   #3
CT Builder
as dec-conc-artisan states .. 6-8-10 triangle works well... and any multiple of it.. ie 12-16-20 works as well...
Daryl is offline   Reply With Quote
Patio cover Jackhammer Building & Construction 3 07-10-2007 04:49 PM
Need help with patio cover supports alexfosse Building & Construction 2 05-02-2007 04:57 PM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 10:00 PM
