Load On Wall From Lumber Storage Rack. Should I Worry? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 09:36 AM   #1
Load on wall from lumber storage rack. Should I worry?
I am converting a garage stall into a woodworking shop. The stall is a third one that was added to an existing two car garage. The wall I want to hang the adjustable steel rack/shelves from is the old exterior wall, now separating the old from the new. It is built of 2x4, and the trusses on the addition run parallel to the wall. I plan to leave the lower 5' for vertical storage of sheet goods and the upper part for boards on the rack. Should I worry about load considerations on the wall ?
rdy2go is offline   Reply With Quote
Old 05-01-2010, 10:54 AM   #2
I'd worry more about fastener pullout and fastener shear strength for your wall material [studs?].
Hillman Hardware's website has or used to have a good tutorial on this.
How 'bout a side view diagram?
Old 05-01-2010, 03:59 PM   #3
I am planning on using dual track steel standards with steel shelf brackets. The brackets are rated 220-340 lbs per pair depending on the size. The tracks have screw holes spaced 11" to 14" depending on the brand, I would think 3 1/2 screws on the studs, with a standard every other stud. Probably 14" or even 19" brackets.
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
windows in a load bearing wall bvpeterson Building & Construction 2 04-27-2009 07:01 PM
Load bearing wall or not? tv4184 Building & Construction 19 01-04-2009 01:12 AM
