Old 03-11-2013, 08:37 AM   #31
Load transfer question
Originally Posted by Fix'n it View Post
yes, i understand that. but the header and "typically" what the header is holding up, doesn't weight much. therefor the trimmer/jack doesn't need to have its own footing. in all that i have seen, the jack & king set on the bottom plate.
So, now your saying the trimmers do not need to bear on a footing or an exterior wall?
mikem201 is offline   Reply With Quote
Old 03-11-2013, 09:09 AM   #32
GBrackins's Avatar
beam supports, whether called trimmers, jacks or columns must bear upon some type of structural element that is capable of supporting the load transferred from the beam. Structural elements can consists of another beam or a footing.
All loads are required to follow a path capable of supporting them down to the ground (where the ground must be capable of supporting loads).
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-11-2013, 10:46 AM   #33
"You can do anything"-Mom
brockmiera's Avatar
I agree with someone earlier that said you should get yourself a framing book or maybe an intro to physics book. At minimum a Statics book would really help you understand the basics of loads and load transfer.
Everyone who understands and has answered here is saying the same thing. I believe it is your limited knowledge and understanding that continues to make this a difficult conversation.
Also stated before, everyone needs to learn somehow, if you have a specific situation at hand then post pictures, drawings, sketches, or a better description and the great folks on here will help you thru it.
If this is for a test, I'd say you're in bad shape.
brockmiera is offline   Reply With Quote
Old 03-11-2013, 10:54 AM   #34
excuse me? When have I disagreed with what anyone has said here? huh big mouth? Keep your damn comments to yourself or I can make a little to call to a person I know that knows someone who "might" be running this site and give them your name.
Old 03-11-2013, 11:17 AM   #35
brockmiera's Avatar
I never once said you disagreed with anyone on here. Feel free to pass my name and comments along to anyone you'd like to. I'm sure they'll see it the same way I do.
Good luck with your project.
Old 03-11-2013, 11:58 AM   #36
GBrackins's Avatar
in the words of that great American Rodney King, "Can't we all just get along??????" we may not always agree, but we all can agree to disagree sometimes
trimmers (also known as jacks & columns) typically support part of the load of a beam, so yes you are correct in that trimmers support beams.
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
brockmiera (03-11-2013)
Old 03-11-2013, 12:02 PM   #37
Average Joe/ex-Navy IC3
gregzoll's Avatar
I am surprised that the mouse has not jumped in and started knocking heads together.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 03-11-2013, 09:56 PM   #38
AHH, SPANS!!!
this thread seems covert -007 - shhh, its a secret
hand drive is offline   Reply With Quote
Old 03-11-2013, 10:07 PM   #39
pretty much everything in a structure is load bearing, to one extent or another. the issue is = does it need to be "directly" supported by the foundation, as the OP is asking. the trimmers in most interior doors do not need to be directly supported . neither are the 2x4's in a non load bearing wall. i would not call a "header" a beam, even though it is to a small extent. to me a beam is something that holds a load and is over 6'. though there are always exceptions.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 03-11-2013, 10:09 PM   #40
mike. don't be hostile = no one will help you then.
and post pics and description of what you want to do, or think you need to do. this will be the easiest path to us helping you understand.
Need Help with calculating load for my transfer switch Durkis007 Electrical 2 01-24-2013 05:01 PM
Generator Transfer Switch Question dme100 Electrical 1 12-28-2011 08:24 PM
bathtub load question thesmackdown Building & Construction 8 06-03-2011 04:47 PM
Structure / Live Load question laurad Building & Construction 1 05-31-2011 06:46 PM
Another Load Bearing Question - Modular Homes ch3howard Carpentry 2 08-17-2008 10:21 PM
