Load Strength Of 6x4 Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 07:49 AM   #1
Load strength of 6x4 posts
I want to install a firepit on top of a deck. If i use 6x4 posts 3' a part in a square, tie them together with 2x6 runners and joists, how can i calculate how much weight that will hold?
TJ Thomas is offline   Reply With Quote
Old 03-25-2012, 10:07 AM   #2
Rewards Points: 77
I think I understand, but your question makes me wonder. Are you using the 4x6's in a vertical position, as posts in the corners, then wrapping with 2x6's to form an enclosed box, then installing floor joists on the inside of the top? If that is the case, the load will go into the joists and how they are attached will be the questionable factor. As for the 4x6's, you could stack a car on the ends of them. What is under them will crush or give out. So, what is under them? You said this fire pit is on a deck. Are the joists under that area doubled up or reinforced with a post underneath? That will be your next load factor, not the posts.
MNsawyergp is offline   Reply With Quote
Old 03-25-2012, 09:44 PM   #3
Rewards Points: 1,092
Weight of the fire pit? If this sucker is going to flatten a one-ton pickup, then you calculate your loads and needs by writing a check to an engineer. Some things are not entirely diy. Let him/her do the calcs, you do the building. It is often cheaper that way.
Old 03-29-2012, 10:21 PM   #4
You need to specify a little more what exactly is going to happen.
diyjohn1234 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Post Load Capacity? echase Building & Construction 13 01-09-2011 12:33 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 11:49 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 06:46 AM
