Load Bearing/Widen Doorway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 06:55 PM   #1
Rewards Points: 878
We would like to widen this doorway entry by shortening the counter. Would we have to provide the same support shown now. We would like to eliminate the vertical support(2x4's) from the counter top up. Thanks.
Load Bearing/Widen Doorway-photo-12-.jpg   Load Bearing/Widen Doorway-photo-13-.jpg   Load Bearing/Widen Doorway-photo-14-.jpg
Mstrlucky74 is offline   Reply With Quote
Old 03-15-2013, 07:00 PM   #2
Rewards Points: 14,010
What's above and below that wall? Any supports?
Look like a none supporting wall due to the single top plate and only 2 X 4 headers.
Old 03-15-2013, 08:22 PM   #3
Rewards Points: 878
Below wall is 1st floor and above is the attic
Old 03-15-2013, 10:03 PM   #4
I agree with Joecaption that it certainly doesn't appear to support anything. You never know in an old house though. You may have wiring to deal with. If in doubt you can always put a header across. Judging by what you have now it would not have to be very heavy. If your attic is trussed rafters you have no worries. Have a peek.
rckkrgrd is offline   Reply With Quote
Old 03-16-2013, 02:20 AM   #5
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
In the last pic it looks like it has a double top plate. To be save change to a 2x6 or greater header with proper jack/king studs on the ends and the proper support underneath the floor to support the system
ryanh is offline   Reply With Quote
Old 03-16-2013, 11:30 AM   #6
which way do the ceiling joists run? parallel or perpendicular to the wall .
Old 03-16-2013, 12:42 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
maybe I'm confused or pinched a nerve by twisting my head to view the photos .... the kitchen is on the second floor?
some questions:
1. what is the opening length? the longer the length the deeper the header typically. which wall are you planning on the opening, the one that the ceiling joists run over or the one parallel to the ceiling joists?
2. is access to the attic above made by a scuttle, pull down stairs or fixed stair case?
3. is there a wall under the wall you want to create the larger opening in?
4. do you have a basement/crawl space or is this a slab on grade.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
Load bearing wall load points KCK44 Building & Construction 6 11-05-2012 08:34 PM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 10:09 AM
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
