Load Bearing Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 06:27 PM   #1
Load Bearing Walls
Hi
Have 2 bedrooms that each have a load bearing wall. Each wall is approx. 11' 4". Would like to remove the walls. What do I have to do? Would like to hae the smallest foot print on the ceiling. What is the smallest "I" beam I can use? Or is there something else? Thanks for any suggestions
hwood71 is offline   Reply With Quote
Old 11-02-2011, 06:31 PM   #2
Framing Contractor
Rewards Points: 120
What you propose is probably doable. No one here can give you the proper size. First step would be to consult an engineer.
sixeightten is offline   Reply With Quote
Old 11-02-2011, 08:54 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
six is right, you need to get an engineer to come in and look at how your house is framed. there are several things to consider such as spans of the ceiling joists, wind load, snow load. how many floors above are supported
the engineer can tell you if it can or cant be done and should draw up a sketch of an exact detail as to how to restructure the framing to accomadate this alteration
woodworkbykirk is offline   Reply With Quote
Old 11-02-2011, 09:53 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Your description of what you are trying to do is just too vague.
If you have some kind of sketch showing the locations and dimensions of the walls in question and what floor they are on and what is above them and what you need to do with the space then maybe someone here can give you a direction in which to proceed.
Many home improvements that involve a structural issue like this can be taken care of without a licensed engineer's approval.
Might be a darn good idea though.
Andy.
AndyGump is offline   Reply With Quote
Old 11-04-2011, 02:43 PM   #5
More Info
HI
OK the length of the wall is 11' 4" width of the house is 24'. Single story house so these walls are supporting the roof rafters. Was thinking of putting a 4"X4" against the outside wall and next to the pocket door that will become the entrance to the master bedroom and some sort if "I" beam. Was really hoping not to have to do double 2"X8" header. Would look really funny I think.
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 10:09 AM
Load bearing walls Brandon760 Building & Construction 5 03-02-2011 08:34 PM
Load bearing wall! Newtsjetson Building & Construction 2 12-19-2010 07:46 AM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Load Bearing walls????? DoubleDD Building & Construction 1 11-23-2009 09:31 PM
