Load Bearing Wall Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 11:50 AM   #1
I am removing a load bearing wall upstairs. Am I safe if I have one of the load points resting on a foundation wall or exterior wall?
Below are pictures. The garage picture is the bottom floor. In the other picture I'm removing that wall (the wall with the return air on the bottom) the load point will go right into the wall (where the door is at). In extends down to the wall in the garage.
Load bearing wall removal-image-1182103397.jpg   Load bearing wall removal-image-1351696571.jpg
jclee is offline   Reply With Quote
Old 02-01-2013, 11:53 AM   #2
Rewards Points: 150
Depends on how much of it is load bearing if the load is right over it yes if not u need a header(blind or exposed)
kaschmid3 is offline   Reply With Quote
Old 02-01-2013, 12:31 PM   #3
Rewards Points: 150
Don't know if I'm comprehending but load bearing refers to weight above it. So if u remove the wall with the vent if there is weight above that wall u need to support it
Old 02-01-2013, 12:38 PM   #4
Sorry. I didn't explain well. I am moving that wall and putting a beam in place. The beam has two load points. One on both ends. I was wondering if one of those load points will be okay if it was located above the foundation wall. From my understanding the load bearing has to go all the way into the foundation
Old 02-01-2013, 12:38 PM   #5
Rewards Points: 150
Judging by the pics the joists go perpendicular with that wall and they r probably seemed over the wall so u would probably need header.
Old 02-01-2013, 12:42 PM   #6
Rewards Points: 150
Should be ok just need to determine of your beam can support the weight above always prepare for more. R u putting in better header, steel plated, or just 2x 10
Old 02-01-2013, 01:09 PM   #7
Rewards Points: 150
R u ok with putting a 4x4 in garage on other point
Old 02-01-2013, 11:52 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
all load bearing points must be brought down to the foundation to properly support the loads. you have to determine the minimum bearing area depending on what that is, i.e., concrete, sill plate, etc.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 01:53 AM
load bearing wall question mudpaws Carpentry 3 06-24-2011 10:39 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
