-   -   Load bearing wall or not? (Pictures) (http://www.diychatroom.com/f19/load-bearing-wall-not-pictures-172489/)
jclee 02-20-2013 01:54 PM
2 Attachment(s)
look at the pictures and tell me if its load bearing.
Picture 1 - attic, to the left is a load bearing wall because I see the joists intersect one another. But the question I have is to the right where you see the roof supports. They run at an angle right down to a wall. Which is picture number 2
Picture 2 - wall. Not sure if its load bearing
brockmiera 02-20-2013 02:02 PM
Move some of that insulation. Are those braces secured to the bottom chord (rafter) or to the wall. The only way they would provide structural support would be if they are attached to the rafter. I dont know how a wall oriented perpendicular to line of action would add any structural support to those diagonal braces.
jclee 02-20-2013 02:13 PM
2 Attachment(s)
Here's some pictures. You can see the wall plate
kwikfishron 02-20-2013 02:34 PM
199 Attachment(s)
They look like purlins to me. They're there to to help support undersized roof rafters.
woodworkbykirk 02-20-2013 03:03 PM
its not a trussed roof, its stick framed.. and im with kwik.. i dont like how the ceiling is framed.. its not strapped which not only gives lateral support to the roof but it also provides a better nailing surface for the drywall especially in corners so the board doesnt flex when its being taped
jclee 02-20-2013 03:09 PM
I guess what im asking is...Can I remove the wall?
brockmiera 02-20-2013 03:57 PM
My vote is.yes you can remove that wall.
loftezy 02-20-2013 04:29 PM
Those are purlins, and as others have stated, they are there to reduce the effective span of the rafters. Without the purlins, your rafters would likely be undersized and you would see a considerable sag in your roof.
The purlins do transfer loads from your roof through the wall, especially during wind and snow loadings. I'll point out that most purlins in my area aren't nailed to the side of the joist like that. They are typically nailed to the top plate.
Can you remove the wall? Maybe. If you do, your ceiling joists will experience point loads, and point loads aren't allowed unless you have an engineer who does calculations to show that it is OK. If you decide to remove the wall, you'll likely have to change how the purlins connect to the ceiling joists and you should be prepared for a sagging ceiling and popped dry wall screws.
brockmiera 02-20-2013 05:08 PM
Whqt size are your ceiling joists? How far do they span? what size are your rafters? Where are you located?
kaschmid3 02-20-2013 06:13 PM
If u do move them u should put collar ties ( 2x4s running parallel with ceiling joist connecting your rafters)
jclee 02-20-2013 08:28 PM
1 Attachment(s)
What about tying the purlins into the load bearing wall like what they did on the opposite end.
jclee 02-20-2013 08:52 PM
well looks like i have my answer....
Purlin Systems
You can also see the purlin system.
Purlin systems are designed to reduce the distance that rafters have to span. They consist of strongbacks nailed to the undersides of the rafters and supported by diagonal braces.
The bottoms of purlin braces should rest on top of a bearing wall. Braces that rest on ceiling joists or which somehow pass the roof load to the ceiling below are defective installations. If you see braces which rest on ceiling joists, look for a sag in the ceiling.
Gary in WA 02-20-2013 10:08 PM
Per Code; http://publicecodes.cyberregs.com/ic...002_par022.htm
Bottom of page for diagram; http://publicecodes.cyberregs.com/ic...002_par023.htm
Gary
