Load Bearing Wall Or Not - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 08:30 PM   #1
Rewards Points: 12
Load Bearing wall or not
Howdy everyone. Bought a small pool table, never been real happy with it as the room is just a hair too small. Either a support beam, the furnace, shelving etc are all in the way.
Well after a couple of beers, a buddy of mine said just knock out the small brick wall/room and we'd have no problems shooting pool.
So..basically in one corner of my basement a 7x7 area is bricked off with a door. The house is about 22 ft wide, with center support beam running down the length of the house of the house.
The brick wall in the basement would be the only place the floor joists have extra support, in the rest of the basement each span is about 12ft on either side of center (and then sunk into the outer foundation wall at the other end).
Lastly there isnt any sort of load over the brick upstairs, just a wood floor on top of it like the rest of the house.
I'm 99.9999% sure this isnt any type of supporting wall, can i a couple of second opinions before I knock it out.
Thanks!
Load Bearing wall or not-3notched.jpg   Load Bearing wall or not-brickroom.jpg   Load Bearing wall or not-inside.jpg   Load Bearing wall or not-parallel.jpg   Load Bearing wall or not-outside.jpg
ezimmerm is offline   Reply With Quote
Old 02-07-2012, 09:05 PM   #2
Rewards Points: 150
Need on site Inspection
Although the photos seem to suggest that the brick wall is not supporting any structure I think you really need someone on site to make a proper evaluation. A Registered Architect or Professional Engineer would best but a knowledgable contractor may work. You really don't want to make a mistake on this. It kind of appears that the intended function may be as a storm safe room.
TheCamper is offline   Reply With Quote
Old 02-07-2012, 09:23 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
it looks like those joists are resting on the brick? I'd consult a professional before I'd start knocking the wall down!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-07-2012, 09:39 PM   #4
Looks like that brick was installed after the joists and its not bearing a load. Load bearing walls are no joke though so indeed a professional on site would be ideal. If it was my place I would build a temporary wall with about 5 or 6 studs about 2 feet away from it just in case , remove it and then install a load bearing beam if needed.
Although it might not have been built to bear a load, the house could have settled to rest on it.
conspikuous is offline   Reply With Quote
Old 02-07-2012, 10:12 PM   #5
Framing Contractor
Thanks!
You have no choice but to have a professional come in to look at this. No one here can tell you if that's a bearing wall it not. It's impossible.
Joe Carola
Joe Carola is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
