Is This A Load Bearing Wall? If So, What Do I Do To Support The Ceiling? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 12:34 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
I'm inclined to think that it's not load bearing either.....
If it was me....instead of a window, I would knock out that column to the right...move the vent over about 2' and frame up a wall about 2' from the door and have the rest of it open.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (09-18-2013)
Old 09-18-2013, 12:39 PM   #17
Rewards Points: 454
Your right,And if he cant do it call a pro in if you cant afford it forget it.I dont no how many times we have to tell him its not a load bearing ,wall he thinks his house is going to fall down by taking a 5' wall out and it right next to a exterior wall. either forget it or jump in there and tear it up.We can only hold your hand so long.Sorry but this going to go on for weeks.
scottktmrider is offline   Reply With Quote
Old 09-18-2013, 12:42 PM   #18
Rewards Points: 454
Originally Posted by Msradell View Post
Considering those beams run parallel to the wall the distance to the wall doesn't mean anything as far as support. If they were running perpendicular to the wall it would make a difference but since they are parallel even 2 feet away from the wall is the same as 40 feet away from the wall as far as support goes.
That being said, it doesn't look like those beams are spliced on top of the wall, the only pass over it. This means it's fairly likely that the wall is not loadbearing.
I you look at the video; the i-joist don't run parrell.
Old 09-18-2013, 01:50 PM   #19
Rewards Points: 588
The I joists rest on that wall perpendicular. I'll post another video of what I see in the attic up above it tonight.
noone is offline   Reply With Quote
Old 09-18-2013, 06:26 PM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 542
Never seen a bearing wall with a single top plate before
Old 09-18-2013, 08:59 PM   #21
Msradell's Avatar
Rewards Points: 170
I was referring to the fact that they are parallel to the exterior wall so the distance from them to the wall makes no difference because they never contact the exterior wall. Obviously they are perpendicular to this wall.
Msradell is offline   Reply With Quote
Old 09-18-2013, 09:15 PM   #22
Rewards Points: 454
Just put a 14" lam beam up for a header and you will be safe.
Old 09-18-2013, 11:19 PM   #23
Rewards Points: 588
I think the ends of these I joists are resting on where this rim board is resting? This is another pic of the area to the right of the drain.
I think I may be ok here now that I've done some research on how lam beams, rim boards and I joists work.
I think I'm finally convinced that this wall is not load bearing.
Is this a load bearing wall?  If so, what do I do to support the ceiling?-image.jpg
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
