Is This A Load-Bearing Wall? Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 01:56 AM   #1
Question
Is this a Load-Bearing wall? Help!
Hey Everyone,
I am a total amateur when it comes to construction. I apologize if some of my terms are incorrect, but I have attached photographs of the original blueprints of the home, and also pictures of what I am talking about.
I just purchased a home, and I am in the process of redoing the basement. I am looking to tear down a wall that is underneath the main beam in the basement. There are three 4" lally columns holding up the beam. There is also the wood that is connected to the beam, which also holds up the drywall.
My question is, are the wood planks also a load-bearing wall?
I would really appreciate it if someone could help me answer the question, can I tear down all the wood, and just keep the lally columns?
If there is anymore information needed, please post!
Thank you very much!
-11Beech
Is this a Load-Bearing wall? Help!-1.jpg   Is this a Load-Bearing wall? Help!-2.jpg   Is this a Load-Bearing wall? Help!-3.jpg   Is this a Load-Bearing wall? Help!-5.jpg   Is this a Load-Bearing wall? Help!-6.jpg
11Beech is offline   Reply With Quote
Old 08-31-2012, 02:36 AM   #2
Rewards Points: 1,092
Excellent job with your posting, but an accurate answer is impossible to give, IMO. PROBABLY the posts are enough, since it does not appear that you have a "footer" all along that wall to support what the wall bears, but I would not bet on it without the original engineer on my team.
Old 08-31-2012, 02:44 AM   #3
Thank you jklingel! I appreciate your speedy response, I will look into that.
Anyone else have ideas/facts/opinions?
Old 08-31-2012, 04:44 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Get somebody in there that knows, it is the ONLY way.
chrisn is online now   Reply With Quote
Old 08-31-2012, 07:58 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The framing (veritical wall studs) underneath the main carrying beam are not load bearing.
However, the triple 2x10 or 2x12 beam itself and the lally column(s) = are most definitely load bearing.
- Build Well -
Old 08-31-2012, 08:00 AM   #6
Rewards Points: 502
Although you would need to get an SE on site to check, I would say it is highly unlikely that the studwork is structural.
Looking at the plan, each 93" span of the beam is supporting about 100 sq ft of flooring. Assuming a total loading of 50 lbs/sq ft (though code may differ) the bending stress in the beam would be well within limits, particularly if the timbers are continuous over the spans, and well-spliced.
(This is assuming it is an open floor above with no walls or partitions etc contributing additional loads to the beam)
I would say it is worth the money getting an SE in to check and confirm this.
tony.g is offline   Reply With Quote
Old 08-31-2012, 12:30 PM   #7
I plan on re-doing my unfinished basement in a typical 1960's colonial house with platform framing. The main beam in the basement is a tripled 2x10" with lally columns that are about 90" apart.
I had a structural engineer come out and verify that my studs attached to the beam were for non load bearing (for drywall installation only) but that concrete filled lally columns were indeed load bearing.
But your situation may be different, so I highly suggest you get a licensed SE for review.
It cost me 300 bucks for his review and an official report but when it comes to something like this, peace of mind is priceless.
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
mae-ling (09-01-2012)
Old 08-31-2012, 12:49 PM   #8
Framing Contractor
Well said!
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-01-2012, 07:18 PM   #9
Registered User
Rewards Points: 4,894
I suggest a S.E. also. Your plans show a 6x10 for the main beam, I presume a two story house for that size timber. The builder substituted 3/2x10's instead, perhaps the frame inspection caught it and required studding below.
6x10 = 1800# per lin.ft.
3/2x10's = 1400# per lin.ft. Quite the difference, ask a local engineer for your snow/roof/story loads.
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
AndyGump (09-02-2012), mae-ling (09-01-2012)
Tags
load-bearing wall
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 04:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
