Load Bearing Wall! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 06:59 AM   #1
Load bearing wall!
I have to put in a door in a load bearing wall. The load bearing beam is horizontal and it holds up the structural integrity of the house. What would be a ballpark estimate of what a contractor will charge me to displace the load bearing beam around the hole that needs to be put in for the door?
Newtsjetson is offline   Reply With Quote
Old 12-19-2010, 07:11 AM   #2
Framing Contractor
No one can answer that here for you. Call a few and ask them. That's the only way you will get the right answer.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-19-2010, 07:46 AM   #3
Rewards Points: 5,336
Your description of a load bearing beam makes no sense. Load bearing beams are not laid on their side(horizontal). As Joe said, get someone in there who knows what he's doing to look at the structure you have. This requires an onsite inspection, not internet speculation.
Ron
Load Bearing Wall Removal Question! Please Help! Evil Scotsman General DIY Discussions 2 10-25-2010 04:52 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 08:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
