Load Bearing Wall?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 12:21 PM   #1
Load Bearing Wall??
Hello, I am attaching a pic of the roof trusses, and a drawing of the floor plan, and what walls I want to remove. I would like opinions on if those walls are load bearing. I keep getting different answers. The house is single level, built in 1980, and is on concrete pad. Block home construction. The yellow highlight shows the walls I want to remove. Based the on the roof truss design, I dont think they are load bearing.
I appreciate it!!
Don
crocs1977 is offline   Reply With Quote
Old 12-09-2010, 01:55 PM   #2
Rewards Points: 5,336
The walls parallel to the front and back of the house have the trusses resting on them. That would be the back wall of the garage with the door to the dining room and the wall line continuing through the middle of the house. They look load bearing.
Ron
Old 12-09-2010, 02:08 PM   #3
question
Ok, so question, what if a I sadwiched some of the trusses in that area with 2x4's, like say 4 of the trusses? Instead of putting in a column and header for support.
Old 12-09-2010, 05:57 PM   #4
I'm not qualified to advise truss modification.
Ron
Old 12-09-2010, 07:26 PM   #5
Framing Contractor
The only people who can answer this is the truss company, or have an architect or engineer come out and look.
Joe Carola
Joe Carola is offline   Reply With Quote
Load Bearing Wall Removal Question! Please Help! Evil Scotsman General DIY Discussions 2 10-25-2010 04:52 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 08:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
