Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 09:27 PM   #1
Rewards Points: 874
Load Bearing Wall
We would(well my wife) would like to open up the kitchen to the other rooms. Can that column with the switch and speaker be removed, or the one to the left or right? Any options(feasible) to open this area up? Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 03-01-2013, 09:54 PM   #2
Rewards Points: 13,732
SIngle story house?
Someone's going to have to go under this area to see if there's a wall, coloum, pipe, some form of support.
Then go in the area above to see which way the joist are run and exactly what's above it.
Is one with the switch in the middle of the house?
Why not leave the coloums in place and just remove the short walls?
Keep in mind anything you remove there's going to be some flooring issues to deal with where they were.
Old 03-02-2013, 01:17 AM   #3
Rewards Points: 1,092
joe's got it. you really need to look at the whole house if that wall is load bearing. a wrong move could be deadly.
Old 03-02-2013, 06:39 AM   #4
Rewards Points: 874
So a structural engineer?
Old 03-02-2013, 06:40 AM   #5
Rewards Points: 874
Originally Posted by joecaption View Post
SIngle story house?
Thanks joe. Yeah good idea but want some counter space to be able to sit toward living room to eat etc.
Old 03-02-2013, 07:00 AM   #6
If the wall that runs from the ref. to the coloum with the switch on it runs from the front or back of the house to the middle that's the most likly one that not load bearing.
But it still needs to be checked over.
Almost every old house I've worked on has had supporting walls removed at some point.
All had sagging ceiling, cracks in the ceiling, and bounce in the floors above because of there mistake.
Mstrlucky74 (03-02-2013)
Old 03-02-2013, 11:20 AM   #7
GBrackins's Avatar
Rewards Points: 2,108
if I were to guess I would think there is a beam above the wall section with the switch.
Joe is spot on, get a professional engineer in there to evaluate your construction and determine a proper course of action or your may not like the outcome. An engineer is cheap money as compared to structural issues.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Load bearing wall? renntecher Building & Construction 2 02-04-2013 01:35 AM
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
