Old 02-04-2013, 01:49 AM   #1
Load bearing wall?
Hi all was wondering if someone can give me their opinion in a wall that I am looking to tear down.
I know that my wall is perpendicular to the wall I want to taken down but does it mean that it is a load bearing wall?
The width of the house is 180 inches and the wall is about 60 inches away from the exterior wall ( brick wall of the house).
Here is the wall I want to take down
https://www.dropbox.com/sc/pt1f38oc94inn7g/LI0jksp2fl
Here is a panorama of my living room and the wall I want to take down
https://www.dropbox.com/sc/586e8l19k8m0c59/yRHDvGyhQw
Here is a pic of my living room and there are no other walls like it.
https://www.dropbox.com/sc/vj5l20wfzwrm1i0/zwbLDNKB0w
I checked that joists run the entire width of the house without having to connect to joists together ( no splicing).
I read somewhere that you can check whether this is load bearing by inspecting the attic. Can someone elaborate on some details for that?
Also, I can check if the top part of that wall is a header, if it turns out that it is not a header can I safely tear it down?
Thanks for your help!
renntecher is offline   Reply With Quote
Old 02-04-2013, 02:28 AM   #2
Load bearing wall?
Far more impostant to see what's below it.
Another wall, extra piers, any form of extra suppost.
Old 02-04-2013, 02:35 AM   #3
Load bearing wall?
I do see another wall pretty close to where the wall offset from the brick wall.
I can take a picture from the basement. The ceiling is a bit exposed there. Anyway I can tell if the wall is right on top of another or is only way to do it measure it from the brick wall?
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 04:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
