Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 06:26 PM   #1
load bearing wall
how can i tell if the wall if want to remove is load bearing?
brend turner is offline   Reply With Quote
Old 09-04-2012, 06:29 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
are there lapped joists that bear on top of the wall?
a photo or two may be able to help in determining
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-04-2012, 06:31 PM   #3
There are several factors to consider here, but the first is this - are the joists running parallel or perpendicular to the wall? Parallel MAY mean it isn't load bearing, but again, more factors to consider. What is above the wall?
Hazel28 is offline   Reply With Quote
Old 09-04-2012, 07:19 PM   #4
Rewards Points: 2,202
Sometimes determining if a wall IS load bearing can be easy, it is harder to determine if it is NOT load bearing.
The best way is to have someone on site to look at it.
The lapping Joists is one of determining Load bearing but there are many other factors to consider as well.
The type of roof system, or second floor, and other things come into effect.
A few months ago we had a guy asking the same question on here, many thought it was not load bearing,
he headed the advice to get someone to look at it and found out it was in fact a load bearing wall.
Not only Load bearing but it could be a Sheer wall depending on your location.
Best advice is to get someone on site to look at it.
mae-ling is offline   Reply With Quote
The Following 2 Users Say Thank You to mae-ling For This Useful Post:
chrisn (09-05-2012), GBrackins (09-04-2012)
Old 09-05-2012, 11:30 PM   #5
Yes, more than anything the shearwalls gets overlooked and is as important if not more important than the bearing wall, esp in seismic regions. Shearwalls can have framing parallel to the wall. Signs of shearwalls include plywood finish under the gypboard, A35 clips, edge nailing and blocking.
luckattack is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 04:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
