Load Bearing Wall?
Its alittle more involved but your basically transfering the load over the opening, whether the header is down in the stud or cut into the ceiling joists the result is the same.
Your roof relies on those joists not being cut to hold up the roof so its more involved with propping and strapping, the header in the wall is easiest option for sure.
If my advise helped you hit "Thanks" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
