Load Bearing Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 05:28 PM   #1
Question
Load Bearing Wall?
Help! I intend to hire a structural engineer or a good contractor for their professional opinion soon, but what do the pros out there think?
Is this a load bearing wall? I want to create a cased opening between my living and dining room as noted below. I think it's load bearing based on the way the supports line up with the wall I want to manipulate - I just wanted to get more opinions before I move ahead. Also, any type of a cost range I should look to spend getting this done by a pro in southeast Louisiana?
Thanks,
Nate
Come by and visit our renovation 'blog': '59ish Brick Ranch: Updating... everything...
natedro is offline   Reply With Quote
Old 08-02-2012, 07:38 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That is load bearing.
tinner666 is offline   Reply With Quote
Old 08-03-2012, 08:19 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,586
Oh yeah...I dare you to prove otherwise....
To the OP, might be time to get an engineer out there.
Old 08-03-2012, 08:32 AM   #4
Well I think it has to be load bearing. In any case, I checked out the IBC span tables and if I want a 5 foot opening, looks like I need 2 8x10s with 2 jack studs on each end. I'm not going to do it myself anyway, but knowing this, any price range to assume so I don't get screwed over?
Old 08-03-2012, 09:58 AM   #5
Rewards Points: 13,694
No one here is going to be guessing a price. Get more then one price and you'll know what a fair price is.
Old 08-03-2012, 10:00 AM   #6
Thanks for the invaluable help. A range is what I was asking for, not a price.
Old 08-03-2012, 12:17 PM   #7
Civil Engineer
Rewards Points: 4,762
Price range depends on how carefully you define the scope of work, where you are located, how busy contractors are in your area, whether you want the contractor to pull a permit (or maybe you don't even need one), and what quality of work you are seeking. As you have not defined any of these parameters, it would be strictly a guess for anyone on this forum to offer an opinion on a price range. Possibly if you carefully define all of the parameters, someone local might have an opinion.
Old 08-03-2012, 12:44 PM   #8
Not so new
12penny's Avatar
Rewards Points: 520
This part always cracks me up.
12penny is offline   Reply With Quote
Old 08-17-2012, 09:58 PM   #9
Beg your pardon? Which part?
Old 08-17-2012, 10:23 PM   #10
Who did that wiring
Totaly againt code to just leave it laying on top of the joist all over the place like that.
And it looks like your way under insulated.
http://www.energystar.gov/index.cfm?...sulation_table
Old 08-17-2012, 10:26 PM   #11
Who did that wiring
Couldn't tell you. House built in late 50s so I've always assumed that was normal for the time.
Old 08-17-2012, 10:55 PM   #12
All the sparkys can quote the exact codes.
But the way I was told by the inspector to do it is simply run them along the lowest point of the roof (near the soffits) or run them between 2, 2 X 4's.
The reasoning is that way no one has to step on them when working in the attic.
There was no good reason for them to be all spread out like that.
Old 08-18-2012, 05:44 AM   #13
Not so new
12penny's Avatar
Rewards Points: 520
Specifically, the screwed over part.
Old 08-18-2012, 06:15 AM   #14
Rewards Points: 150
Hard to tell from the pics but it probably just needs a header, 2-2x10 nailed together would be plenty.
There is no floor load above so your just holding up sheetrock ceilings at that point.
Is the house on a slab or a basement?
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-18-2012, 08:32 AM   #15
Slab.
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
