Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 07:13 PM   #1
Rewards Points: 672
Load Bearing Wall
Hey gang. My Super Bowl pregame consists of framing in a doorway for a basement bathroom in a load bearing wall. I KNOW, no one will tell be that I am doing everything correctly. I am just looking for some insight, perhaps someone had done this before.
My first question, in the pics you will see my footers are above ground. Would you think that they are cement blocks sitting on in ground footers? That they at least go down to the bottom of the poured floor?
My plan is to remove the two vertical 2x4s (I have no posts, just 2x4s supporting a staggered 2 2x4 beam), put in a 4x6 header with treated 4x4 posts on each side of the doorway 34" apart and a 2x4 jack post at the other end of the 4x6, and cut the raised footer flush with the floor. The 4x4 posts will be flush with the floor and the raised footer will be cut to the outside edge of each 4x4.
In researching I found that a 4x6 could span further than 34" (I think 48") with a one story above, 14' joists. More to the point, a doorway 6 feet down the line is supporting two joists on a 2-2x4 header. I think I am overkilling it so I can sleep more soundly.
Any input?
B
Beepster is offline   Reply With Quote
Old 02-04-2012, 08:40 PM   #2
Rewards Points: 1,092
I don't think anyone can say why you have a wall on blocks, why there is not treated lumber against the blocks, and what is below the blocks. I think you'll have to dig in there w/ bits to see WTH is below. I also do not know why a load bearing wall is sitting on empty cement blocks. I don't think that is an appropriate way to use them, as they'd be subject to failure as used, IMO. If the header 6' down the road is working, put in a heavier one, like you suggest. Overkill never hurts. For your new studs on the concrete, I'd sure put an EPDM gasket between them, to stop wicking.
Old 02-04-2012, 09:08 PM   #3
Rewards Points: 672
I was just wondering if this was a practice of a certain era (1957) or region (Minneapolis). The house is solidly built so I don't have any qualms about half assed work being done. Was it built this way where water could be a potential problem (not in my house)?
B
Old 02-04-2012, 09:29 PM   #4
Framing Contractor
B
Who knows. No one can tell you this. So don't go cutting and ripping anything out until you find out by having someone look at it..
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-05-2012, 04:17 PM   #5
Rewards Points: 672
Well that was relatively painless. The "raised footers/cement blocks" continued down below the top of the cement floor. I would guess, and I have been wrong guessing with this house, that they are 4"x8"x16" cement blocks sitting on the center footers when the floor was poured. I now believe this area is stronger with 4x4 posts holding up the header than the 2x4 that were there before.
On to The Game. C'mon...can both teams lose?
B
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
