Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 08:36 PM   #1
Load Bearing Wall
If a wall was a load bearing wall would it not run across the whole house? I am looking to take a wall down that sits below a beam. Above the beam are two bedrooms and the walls are no where near the beam. The wall that I would like to take down is dividing the living room from a bedroom. Any suggestions?
renogirl1 is offline   Reply With Quote
Old 01-12-2012, 08:42 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Not necessarily. Depends.
Draw a picture for us.
titanoman is offline   Reply With Quote
Old 01-12-2012, 08:55 PM   #3
MarginallyQualified
Rewards Points: 2,464
In principle... yes. But it can be built to carry that load in other ways too.
For example the header over a door or opening.
Above the beam... is another world
Be careful.
Be prepared to ADD a header or such to any long span...
and for the possibility that some portion of the wall (or a new post)
will still be needed to carry the load.
And also consider what mechanical's are in that wall...
HVAC duct? water pipes? drain pipes? electrical?
hth
Old 01-12-2012, 09:54 PM   #4
Rewards Points: 1,092
How are you sure the wall carries anything if it sits below the beam? It could be only a partition wall. It would be advisable to get an engineer to look at the situation and determine if the beam can take the load by itself. If the wall IS load bearing and you remove it, then what is going to take the load that it used to? If only the beam will, then you better make sure that what holds the beam up, from below grade up to the beam, was designed to do that.
Old 01-12-2012, 09:56 PM   #5
Rewards Points: 2,212
Best to get someone to look at it. There are a few ways to tell. I would hate to give you advice and have your house fall apart on you.
mae-ling is offline   Reply With Quote
Old 01-13-2012, 09:18 AM   #6
Beanfacekilla's Avatar
This is a popular topic here.
If you don't know how to tell if a wall is load bearing, I don't think you are ready to move it (or take it down, whatever).
If you are going to attempt this project, consult an experienced archy or engineer first. They will be able to tell you how to properly complete the task.
Just my $0.02
Peace.
Beanfacekilla is offline   Reply With Quote
Old 01-13-2012, 12:49 PM   #7
Civil Engineer
Rewards Points: 4,856
It is ABSOLUTELY incorrect to assume that a wall is non-load bearing simply because it does not span across an entire house. Many houses are built in stages, and the original wall could be load bearing, but was not extended to the addition, which could have been framed 90 degrees off the original. Not uncommon. It is also dangerous to assume that a beam supported by a wall does not require the wall for support. This assumes that the beam was properly sized to span the gap without need of intermediate support.
The only way to tell if a wall is load bearing is to draw an accurate diagram of the framing to determine the load path from the roof to the foundation, to see if any of the load goes through the wall. This is not as simple as it sounds, if you have any doubts about your ability to undertake this, seek professional assistance before you touch the wall.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
woodworkbykirk (01-13-2012)
Old 01-13-2012, 01:43 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 546
As much as I hate to agree with an engineer, Holzman is right here.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
mae-ling (01-13-2012)
Old 01-13-2012, 06:59 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
daniel is right, in some homes the framing can be pretty involved, with all kinds of bearing points, beams and sections of floor joists that change direction. some of the places that i have framed make experience framers scratch their head.. some of these have bearing walls that range from 2' long all the way up to 30' ft long . it depends on what the architect dreamed up when designing the place
woodworkbykirk is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
