Load Bearing Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 12:45 AM   #1
Load Bearing Wall?
We have a small galley kitchen that we are wanting to expand by removing an 8ft wall with a door that connects the kitchen and laundry room. I am trying to determine if this a load bearing wall, and if it is....is it short enough that the studs in the perpendicular walls will hold it up if it is?
I've attached a simple floor plan of the house to help. It's 1250 sq ft, slab foundation, 1 story.
melandjar is offline   Reply With Quote
Old 09-25-2011, 01:31 AM   #2
its impossible to tell with just that info. In fact, impossible to say for sure via the internet regardless. Only an educated guess.
which way are the joists running?
acerunner is offline   Reply With Quote
Old 09-25-2011, 06:02 AM   #3
DIY staff
Rewards Points: 7,174
Is the roof stick built or is the roof trussed? That will be a big help.
Need more info--but the likelihood is that is a partition and not a bearing wall.
Old 09-25-2011, 08:17 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
if its the wall i think it is, it most definitely will be a load bearing wall if the roof is stick framed, if its trusses it shouldnt be a problem. even still i would consult a contrator locally who can better examine the attic space to look at the roof system
woodworkbykirk is offline   Reply With Quote
Old 09-26-2011, 12:22 PM   #5
The roof is truss built and they run perpendicular to the wall. It is the wall between the kitchen and existing laundry room (I put an arrow to it), and the wall that runs through the living room will remain.
Old 09-26-2011, 12:35 PM   #6
Civil Engineer
Rewards Points: 4,956
You need to post photos of the framing. A lot of people do not understand what a truss is, and mistakenly think they have trusses when they do not. The definition of a load bearing wall is a wall that holds more load than its own weight. The only way to tell if a wall is load bearing is to examine the structure immediately above the wall to see if there are any structural elements such as floor joists bearing on the wall. It is simply impossible to tell from your diagram, you need to post pictures and a diagram of the framing above the wall.
Old 09-26-2011, 12:39 PM   #7
Ok thanks, will get some pictures up.
Old 09-26-2011, 09:28 PM   #8
Here are pictures, in the first one(above the kitchen) the wall in question is running parrallell to the roof supports, whereas in the 2nd picture (above the rest of the house) it is perpendicular. However the change is above the wall that is in between the living room and kitchen which is not going anywhere.
Load Bearing Wall?-above-kitchen.jpg   Load Bearing Wall?-above-living-room-bedrooms.jpg
Old 09-26-2011, 10:15 PM   #9
looks like straight forward trusses, you should be fine but still consult a contractor
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 03:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
