Load Bearing Wall?! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 09:11 AM   #1
Load bearing wall?!
Hi,
We've just bought a house, and there's a wall that's in the way of my dream size wardrobe
Links to the pics : http://www.flickr.com/photos/62186917@N02/
The logic says 'there's nothing on it!!' But can somebody please reassure me?!
IMG_8924 shows the whole situation the best - or so I think..
The wall was built on a wooden plank on the floor and is no way connected to the downstairs walls..
Thank you,
Siga is offline   Reply With Quote
Old 05-10-2011, 11:48 AM   #2
Just a DIY guy
Originally Posted by SharperCleaning
A load bearing wall gives a building structural integrity. It carries and distributes weight from the roof and top floors down to the foundation. Know that the outside walls of your home are always considered to be load bearing because these walls support the roof. Additional support has to be given to these walls when any modifications are performed. Locate interior walls of your home that run perpendicular to the rafters. These are load bearing walls.
Perpendicular walls are not always load bearing. If you have engineered trusses in the attic above them, chances are it's not load bearing BUT it's not that easy, you have to see if the truss is rigidly attached to that wall.
M3 Pete is offline   Reply With Quote
Old 05-10-2011, 02:28 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Another reason a wall may not be a load bearing is if the room is narrower in width than it is long. Example, a room say 14X20 feet you wouldn't use 20 foot ceiling joist just to tie the outside walls together, that could be done in different ways.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-11-2011, 12:02 PM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
Hard to say for sure from just a couple photos.
Aggie67 is offline   Reply With Quote
Old 05-11-2011, 01:30 PM   #5
General Contractor
LakeTahoeDan's Avatar
If the wall was built on a floor that is not directly supported below then it is not a load bearing wall. (if it was built properly to begin with) If the wall is a load bearing wall then the "load" would carry straight down to the foundations or footers. Or there would be a beam the wall is built on.
LakeTahoeDan is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 08:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 06:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
