Load Bearing Shim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 02:21 AM   #1
Load bearing shim
I have an lvl beam which is supported by a column at one end and the beam is fastened to this column using a Simpson Strongtie end cap. This end cap is bolted to the 2x6 and the lvl using grade 5 bolts 3/4" dia. The column is made of built up 2x6 but there is a small gap at most approximately 0.05" I know it's little but this still means the beam is not fully rested on the column and the bolts are taking the load, should I shim with steel shim stock or any other solution?
ojee001 is offline   Reply With Quote
Old 12-07-2010, 07:09 AM   #2
Rewards Points: 1,658
I would if I could; makes sense to have the load properly transferred to the king studs and not relying only on the Simpson fixture.
bob22 is online now   Reply With Quote
Old 12-07-2010, 09:38 AM   #3
Did you mean 0.05" or .5"?
mrgins is offline   Reply With Quote
Old 12-07-2010, 09:41 AM   #4
I meant 0.05" I know it doesn't sound like much but it still means the cap isn't sitting on the column, probably gonna get steel shim stock
Old 12-07-2010, 10:30 AM   #5
The older I get the better I was
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
