Load Bearing Removal: Hidden Beam Or Exposed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 10:20 AM   #1
Load Bearing removal: hidden beam or exposed?
in this video , the support beam extends below the ceiling. I've seen others cut the ceiling joists and slip up a beam with brackets to hide the beam in ceiling.
Seems to me like the latter is more difficult and more aesthetically pleasing, while the first is much easier to do.
What are you opinions? As far as support, Is one better than the other?
jclee is offline   Reply With Quote
no support under load bearing wall? foxmanb Building & Construction 1 03-26-2012 12:04 PM
Removal of Part of Load Bearing Wall Costs NickWa Building & Construction 6 01-24-2012 11:36 AM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 07:11 AM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 08:12 AM
Beam Load Ron Building & Construction 5 09-17-2006 07:28 AM
