Load Bearing For A Recording ISO Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 07:07 PM   #1
Hello all,
I have a big open space in my basement, which has a concrete slab for a floor. I intend to build a room in this space. None of the walls or ceiling of my new room will touch any of the structure that is my house (ecept the floor). I was planning on constructing 2 by 4 walls (bottom plate pressure treated lumber, two top plates, studs 16" oc). I was thinking about using 2 by 4's as the ceiling joists. My concern is whether or not 2 by 4 ceiling joists will be able to handle the weight of 2 layers of 5/8s drywall pulling down or not? Will the 2 by 4 walls have any issue either? I've spent many hours trying to find a similar scenario but have come up empty handed.
Someone set me straight please!
EyeVeeDrip
Forgot the room dimensions
75"w by 104"l by 85"h
eyeveedrip is offline   Reply With Quote
Old 05-03-2010, 01:59 AM   #2
liscenced electrician
Rewards Points: 538
id use 2x6's.
if this is for recording, there is a technique you can use for your walls. Use 2x6 on your top and bottom plates and frame with 2x4's. Line up the outside of the 2x4 to one side of the 2x6 and move the next 2x4 to the other side of the 2x6. Then that leaves space inside your walls, that you can interweave insulation into. Doesn't transfer sound that way.
jimmy21 is offline   Reply With Quote
Old 05-03-2010, 09:15 AM   #3
Thanks for the reply.
Ive seen that technique before. It's pretty cool.
So to rephrase what you said, 2x4 for the walls would be good, but you'd encourage me to use 2x6 for the ceiling joists, correct? I can certainly do that, I'll just need to reduce my height by 2".
Old 05-03-2010, 02:20 PM   #4
Rewards Points: 538
you can get away with 2x4 if you really want. 75'' isnt very far. i wouldnt use 2 layers of sheetrock, though. use a layer of soundboard and cover with sheetrock. its like crappy particleboard. it not dense on purpose though, to not transfer sound
Old 05-03-2010, 03:57 PM   #5
There are also some quiet GWB products that are used primarily in hotels and multi-unit buildings that have a lower sound transmission designed into them.
http://www.quietrock.com/quietrock-drywall.html
http://products.construction.com/Sea.../sound%20proof
There are also a number of aftermarket products that you can apply to your walls to limit sound transmission and reflectance - foam panels, natural fiber panels etc
cellophane is offline   Reply With Quote
Load bearing wall? Bozol Carpentry 16 02-18-2010 10:52 AM
Load Bearing Half Walls??? HoneyDo007 Building & Construction 5 10-05-2009 12:53 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Load bearing wall or not? tv4184 Building & Construction 19 01-04-2009 02:12 AM
