Load Bearing Beams? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 07:00 PM   #1
Load Bearing beams?
I have 1 beam (wooden) running the length of my living room. Coming off that beam are 8 smaller beams running from the that center beam to the wall. Is there anyway to determine if it is load bearing? I want to get rid of all the beams...help?
GSaunders02 is offline   Reply With Quote
Old 06-15-2009, 07:02 PM   #2
What kind of beams?
Are they exposed ceiling beams?
How far apart are they?
Is there an attic or 2nd floor over this?
If 2nd floor is there a wall over the beam?
Old 06-15-2009, 07:09 PM   #3
the Musigician
DangerMouse's Avatar
Old 06-15-2009, 07:15 PM   #4
I leave PM's off on all the sites
IT seems that some people seem to think that it means "Private Messaging" & I think it means "Public Message". These people think they can send you anything they want (bad) via PM without repercussions. One guy found out that it is not so as I made public his "ranting" PM. He was quite upset that the bad side of him had been brought out into the light
The owner of the site went in & deleted the PM to me
So I had no proof that he actually sent it
So now I receive everything via E-mail (web based)
Sorry
Ah - the solar spammer
I listed several links to sites with "how to's" on paragraph & sentence structure
Old 06-15-2009, 07:23 PM   #5
the Musigician
ok, just curious... GSaunders: they might even be styrofoam fake beams, i've seen them before....
can you take photos and post them?
DM
Old 06-15-2009, 09:28 PM   #6
Registered User
Rewards Points: 5,246
Could we see a picture of the beams and a picture of the attic above the beams, please? Be safe, G
Gary in WA is online now   Reply With Quote
Old 06-17-2009, 05:31 PM   #7
beams?
Sorry for the delayed response. Ok. Here's a pic of the beams. The beams are wooden. There is only an attic crawl space about this ceiling. They aren't exposed ceiling beams as there is drywall above the beams. Any thoughts?
Old 06-17-2009, 05:39 PM   #8
the Musigician
if they're solid beams, i dare say they hold up the roof/ceiling, and if they're 3 sided 'fake' beams, they are likely wrapped around a stud, so, same thing pretty much.
orrrrr..... they could also be totally fake and just there because the guy didn't like to tape and mud seams... are they about 4 and 8 foot sections perchance?
maybe try to pull one apart a little to see what exactly it is?
on second look, i'm betting the latter....
DM
Old 06-17-2009, 06:01 PM   #9
Registered User
"as there is drywall above the beams." Fake. Ok, DangerMouse, You made me think I was losing it, for a minute anyway. I asked for pictures when I thought no one else did........... Then I see your question. Then I noticed you edited it 4 minutes after me. lol...Be safe, G
Old 06-17-2009, 06:41 PM   #10
the Musigician
hehehehe sorry if i confused you....
DM
Old 06-22-2009, 01:52 PM   #11
They are exactly 4 feet apart...'m going to look behind and see what its hiding. If its a seam, can I aaume that they are not load bearing?
Old 06-22-2009, 01:59 PM   #12
the Musigician
i dare say so.... let us know what you find!
DM
Old 06-22-2009, 02:20 PM   #13
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
Fake basically covers
There may be a 2x4 cleat underneath them but I am guessing the house is 1950 - 1980 vintage. People thought these looked good and all you have to do is take them down. You will probably find that the 2x4 cleat underneath them is etiher screwed into the framing but then they may have used an air nailer and cleated a 1000 nails in each one of the boards.
Welcome to the year 2009 and get those beams out of there! LOL
You may have to address that ceiling fan as the wiring might run inside the one beam but you won't know until you pull. Take down the ceiling fan and then go at it (make sure you turn off the circuit breaker prior).
Good luck and you will then have some scraping, patching, texturing and painting to bring it around full circle but the difference will be amazing!
Good luck and be safe!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 06-22-2009, 04:57 PM   #14
Excellent!! Thanks for the replies everyone. I will post pics after I remove the beams!
Old 08-22-2009, 04:58 PM   #15
Well, I did end up taking the beams out and they were not load bearing. However, the seams under those beams were not even and I am stuck going into the crawlspace to add extra joists to "marry" the two beams so the seams will come together so the taping/mudding will finish correctly And beyond that, de-construction of the current walls starts Tuesday...concerned on what I may find behind those walls
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 07:19 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 10:23 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
