Load Bearing Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 09:58 PM   #1
load bearing beam
My son is building a new house and wants an open floor plan, so he has the builder installing a beam that spans the living room and makes the kitchen and dinind room open to the living room. The problem is he just wlaked under the beam and has only 4 to 5 inches clearance and that is before the drywall is added and before any flooring/carpet goes down. What can be done before the second floor is added next week and it will be too late to do anything but duck the beam.
nursenmaryland is offline   Reply With Quote
Old 06-25-2010, 10:07 PM   #2
How tall is your son ?
What is the measured clearance ?
This should have been taken care of before the beam was installed
Old 06-25-2010, 11:32 PM   #3
Rewards Points: 6,652
Guess that who ever is building the home is not following the plans that the architect drew up. This would also have to pass inspection by the local inspector, before they can even proceed on the second story.
Old 06-26-2010, 06:45 AM   #4
kwikfishron's Avatar
Rewards Points: 1,008
There are clearance codes.
Can something be done? Probably. The first step is to stop the framers and talk to whoever drew up your plans and have them revised, if feasible.
kwikfishron is online now   Reply With Quote
Old 06-26-2010, 06:48 AM   #5
Rewards Points: 5,336
The next inspection would be when the framing was complete. All the framing. I've never had a floor by floor inspection in NY.
Was this beam thing a modification of the original plans?
Contact the Architect for a solution. This should have been addressed long before anyone picked up a hammer.
Ron
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 10:31 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
