Load Bearing Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 05:47 PM   #1
load bearing beam
This job is probably over my head but here is question,My daughter wants to fully open up ist floor dine,kitchen and living room,i like to know what type of beam spanning 25 feet with a 2nd floor and roof on top of that.can a wood beam do it or is steel necessary thanks bill
billlll is offline   Reply With Quote
Old 08-03-2011, 05:53 PM   #2
Rewards Points: 150
There is engineered wood like
Gluelams, lvl and wooden I-beams that will Span that distance.
Broughton is offline   Reply With Quote
Old 08-03-2011, 05:57 PM   #3
DIY staff
Rewards Points: 7,174
25 feet is a long span---to long to take a guess on---you will need an engineer to figure out that one.
Before you spend that money you should see if the idea is practical.
Removing the wall usually means moving heating ducts and air returns--and plumbing drains and water lines----That may be the 'deal breaker' with that wall.
Before you hire someone to engineer the beam--see what is hiding inside the wall.
Old 08-03-2011, 06:03 PM   #4
Civil Engineer
Rewards Points: 4,770
At 25 feet, engineered lumber is likely to be relatively deep, maybe too deep for the opening. You may need steel, but as Mike suggested, this is potentially expensive project, absolutely needs to be engineered, and if you have to move a lot of wire etc., may not be worth it.
Daniel Holzman is online now   Reply With Quote
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 05:27 PM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
How to determine if it's a load bearing wall? tripower Building & Construction 8 12-30-2008 09:42 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 07:12 AM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
