Load Bearing Basement Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 09:02 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Load bearing basement wall?
Hi all. I was pretty-sure I'd be able to remove these walls, then after looking at them I'm not sure. The joists above this wall sit on the concrete foundation on the one side, and span over to what is seen in this picture. It's about 3' from the foundation wall to the bottom of the stairs.
Just thought I'd see if anyone here could give it a shot before I have to seek professional advice. It doesn't look like it is supporting all 4 of the joists, so it wouldn't be load bearing - but I'm not a structural engineer/architect. I really wanted to have an open staircase when I finish this basement, which will be starting soon.
Wall 1:
Wall 1 where the joists meet the I-beam
Wall 1 at the other side.
Wall 2 is trickier. Obviously the stack of 2x4s is important and has to stay. However, can I remove the rest of the wall?
Wall 2:
Wall 2 above the supporting stack of 2x4s
Wall 2 on the other side:
Thanks in advance.
Load bearing basement wall?-wall1-medium-.jpg   Load bearing basement wall?-wall1left-medium-.jpg   Load bearing basement wall?-wall1right-medium-.jpg   Load bearing basement wall?-wall2-medium-.jpg   Load bearing basement wall?-wall2right-medium-.jpg
hyunelan2 is offline   Reply With Quote
Old 12-12-2011, 09:34 PM   #2
Rewards Points: 5,336
Interesting framing next to the stairs. What do you have above this that requires all the wood?
Ron
B. Franklin 1759
Old 12-12-2011, 09:36 PM   #3
Leave the stack of 2x4 alone. Cut remaining on a slant to give yourself a rail with a 1x6
WeAreHandy is offline   Reply With Quote
Old 12-12-2011, 09:46 PM   #4
hyunelan2's Avatar
Rewards Points: 692
Above this is just the side of the open staircase between the fist and second floors. It looks like its real purpose is the side of the joists that are running perpendicular to the wall.
Old 12-12-2011, 09:48 PM   #5
hyunelan2's Avatar
Rewards Points: 692
That was the idea, just making sure they can come out. Also curious as to why the wall is even there off its not necessary. Would just be wasted cost to the builder.
Old 12-13-2011, 09:48 AM   #6
Cost on material vs cost on labor. The wall is there cause its easier for the builder to build wall for safety proposes instead of rail (as to what u want to do)
Old 12-13-2011, 10:37 PM   #7
Registered User
Rewards Points: 5,498
The wall extends to the bottom riser to meet minimum fire/safety code per jurisdiction locally- IRC, UBC, etc. light switch, handrail return, drywall sidewalls per code, ect.
Before removing any of the wall you need to verify the built-up joist (ganged) nailing pattern is to code- hard to do when covered by other joists. You cannot check the middle joists, bolting may be an option, contact your local AHJ.
Check your span/loads for the ganged joists (with/without the helping wall section) in wood tables.
Gary
Old 12-14-2011, 10:05 AM   #8
hyunelan2's Avatar
Rewards Points: 692
For now, I'm just going to start framing the other walls and leave those alone. Due to budget cutbacks, our city now has ONE inspector, who is on vacation until next Tuesday.
If it turns out I can't remove the walls, I guess I can live with it. Or, perhaps put support poles/pillars at the bottom of the stairs and open up the sides a bit. Something like this:
Old 12-14-2011, 03:45 PM   #9
From what I can see the wall isn't supporting anything! i would get a second opinion!
Old 04-23-2012, 11:36 PM   #10
Question
Update?
Did you end up doing this with a semi-open stairwell?
We have the same design dilemma with our basement stairwell.
meseng is offline   Reply With Quote
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 10:14 AM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
