-   -   Load bearing basement wall? (http://www.diychatroom.com/f19/load-bearing-basement-wall-126458/)
hyunelan2 12-12-2011 09:02 PM
6 Attachment(s)
Hi all. I was pretty-sure I'd be able to remove these walls, then after looking at them I'm not sure. The joists above this wall sit on the concrete foundation on the one side, and span over to what is seen in this picture. It's about 3' from the foundation wall to the bottom of the stairs.
Just thought I'd see if anyone here could give it a shot before I have to seek professional advice. It doesn't look like it is supporting all 4 of the joists, so it wouldn't be load bearing - but I'm not a structural engineer/architect. I really wanted to have an open staircase when I finish this basement, which will be starting soon.
Wall 1:
http://www.diychatroom.com/attachmen...1&d=1323744975
Wall 1 where the joists meet the I-beam
http://www.diychatroom.com/attachmen...1&d=1323744984
Wall 1 at the other side.
http://www.diychatroom.com/attachmen...1&d=1323744997
Wall 2 is trickier. Obviously the stack of 2x4s is important and has to stay. However, can I remove the rest of the wall?
Wall 2:
http://www.diychatroom.com/attachmen...1&d=1323745158
Wall 2 above the supporting stack of 2x4s
http://www.diychatroom.com/attachmen...1&d=1323745172
Wall 2 on the other side:
http://www.diychatroom.com/attachmen...1&d=1323745183
Thanks in advance.
Ron6519 12-12-2011 09:34 PM
Interesting framing next to the stairs. What do you have above this that requires all the wood?
WeAreHandy 12-12-2011 09:36 PM
Leave the stack of 2x4 alone. Cut remaining on a slant to give yourself a rail with a 1x6
hyunelan2 12-12-2011 09:46 PM
Above this is just the side of the open staircase between the fist and second floors. It looks like its real purpose is the side of the joists that are running perpendicular to the wall.
hyunelan2 12-12-2011 09:48 PM
That was the idea, just making sure they can come out. Also curious as to why the wall is even there off its not necessary. Would just be wasted cost to the builder.
WeAreHandy 12-13-2011 09:48 AM
Cost on material vs cost on labor. The wall is there cause its easier for the builder to build wall for safety proposes instead of rail (as to what u want to do)
Gary in WA 12-13-2011 10:37 PM
The wall extends to the bottom riser to meet minimum fire/safety code per jurisdiction locally- IRC, UBC, etc. light switch, handrail return, drywall sidewalls per code, ect.
Before removing any of the wall you need to verify the built-up joist (ganged) nailing pattern is to code- hard to do when covered by other joists. You cannot check the middle joists, bolting may be an option, contact your local AHJ.
Check your span/loads for the ganged joists (with/without the helping wall section) in wood tables.
Gary
hyunelan2 12-14-2011 10:05 AM
For now, I'm just going to start framing the other walls and leave those alone. Due to budget cutbacks, our city now has ONE inspector, who is on vacation until next Tuesday.
If it turns out I can't remove the walls, I guess I can live with it. Or, perhaps put support poles/pillars at the bottom of the stairs and open up the sides a bit. Something like this:
http://limegreenpink.com/Stairs/stairsx.gif
Wildie 12-14-2011 03:45 PM
From what I can see the wall isn't supporting anything! i would get a second opinion!
meseng 04-23-2012 11:36 PM
Update?
Did you end up doing this with a semi-open stairwell?
We have the same design dilemma with our basement stairwell.
