Is This Load Bearing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 10:14 AM   #1
Is this load bearing
Hi all, new here and am starting some renos. What I thought was a good wall to remove now has me second guessing. Can I get your opinion??
The house is built in 1955 and is a bungalow. The wall is above a double 2x10, (as every wall in the house is) but no wall under, and on the main floor it butts into the main load bearing wall running the length of the house (which sits on cinder block wall). The wall to be removed is parallel with floor and ceiling joists.
I am trying to upload pictures, but having trouble, will work on it.
Thanks in advance
gwilliams17 is offline   Reply With Quote
Old 01-11-2011, 10:42 AM   #2
to add - just up in the attic, and it pretty much confirms. The wall is in the middle of 2 of the rafters.
Would still like any input if there is any, thanks.
Old 01-11-2011, 10:48 AM   #3
Experienced
Jackofall1's Avatar
As always pics help, but if the wall you are referring to is between rafters then it is not carrying any load.
Old 01-11-2011, 10:58 AM   #4
finally figured out how to get the pics up...
views in no order:
1 - entire wall
2- where wall meets load wall
3. from under wall in basement
as I said, it doens't look as though the wall is even under a ceiling joist, but that double 2x10 scared me. Could that just be for the weight of the wall itself?
Is this load bearing-img_1159.jpg   Is this load bearing-img_1156.jpg   Is this load bearing-img_1160.jpg
Old 01-11-2011, 11:09 AM   #5
Maryland
Thanks in advance
If the wall in question is perpendicular to a known load-bearing wall and parallel to the floor and ceiling joists, then it most likely is not a load bearing wall. For added peace of mind, you could always consult with a structural engineer. Best of luck!
Pittsville is offline   Reply With Quote
Old 01-11-2011, 11:17 AM   #6
rditz's Avatar
do you have access to the space above, into the attic. That would be the best place to confirm if this wall is carrying a load.
the other way to find out would be to open up some ceiling drywall.. (looking at your pictures, you will be doing some patching anyways, so a little more won't hurt). cut some drywall along the wall and check for a load on it. If it is running parallel to the ceiling joists above, then I would think that it is not bearing any load from that ceiling.
good luck
rod
rditz is offline   Reply With Quote
Old 01-11-2011, 11:19 AM   #7
Experienced
Jackofall1's Avatar
Guess you missed this rditz
Old 01-11-2011, 11:21 AM   #8
rditz's Avatar
Jack,
Yup!, pretty much skimmed right over that...
gwilliams, go for it.. hahaha
rod
Old 01-11-2011, 11:41 AM   #9
thanks guys, all the help is appreciated!
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 10:14 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
