Load Bearing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 01:42 PM   #1
GLK
load bearing
How much weight (at the middle) will an 11 ' douglas fir 4X4 carry? Supported at the ends.
GLK is offline   Reply With Quote
Old 01-25-2014, 10:44 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Maybe one child on a swing.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 01-26-2014, 08:32 AM   #3
Rewards Points: 502
Depends how much deflection you are prepared to tolerate.
tony.g is offline   Reply With Quote
Old 01-26-2014, 09:12 AM   #4
Civil Engineer
Rewards Points: 4,862
According the the Forestry Forum (http://www.forestryforum.com/members/donp/Fblist.htm), douglas fir has an allowable maximum fiber bending stress ranging from 875 psi for #2 to 1850 psi for dense select structural. Let's take the worst and the best case for you. Assume that your 4x4 is actually 3.5 inches by 3.5 inches.
Worst Case 875psi: 190 lbs at the midpoint
Best case 1850 psi: 400 lbs
These values provide a factor of safety of 1.0 in bending. This does NOT analyze for deflection, which may be important in your case. This does NOT analyze for shear, which may be important. This analyzes for a STATIC load only, does NOT account for dynamic loads such as a swinging load. This does NOT account for repetitive loading or fatigue, which may be important in your case.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 01-28-2014, 07:53 AM   #5
General Contractor
Gary Evans's Avatar
Those are some good numbers Daniel.......good to know.
What's important to GLK is the weight this will support at mid span..........I'd stick to the lower half...........200 - 300 lbs.
Provided there's not a big knot anywhere near the mid span, which could weaken the 4x4 a lot.
If this is a dynamic load ( a swing for instance) what's your best guess Daniel for reducing that weight rating ?
Also I think deflection is more of a concern than shear.......providing there's proper bearing support at the ends.......at least 2" .......3" would be better.
Gary Evans is offline   Reply With Quote
Beam for Load Bearing Wall jstein69 Building & Construction 3 02-17-2012 05:26 PM
Removing Kitchen Soffit - load bearing?? adrien2 Carpentry 4 09-25-2011 06:29 PM
Determining a Load Bearing Wall (Pic Included) Evil Scotsman General DIY Discussions 18 03-02-2011 02:46 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 09:23 PM
