Is This Load Bearing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 09:07 AM   #1
Is this load bearing?
I don't believe it is. Check out the picture.
jclee is offline   Reply With Quote
Old 10-17-2013, 09:30 AM   #2
cortell's Avatar
Rewards Points: 504
The exposed wall is definitely not
cortell is offline   Reply With Quote
The Following 2 Users Say Thank You to cortell For This Useful Post:
Gary in WA (10-17-2013), Windows on Wash (10-17-2013)
Old 10-17-2013, 09:37 AM   #3
I know that. I'm talking about the stacked 2x4s that runs up the to the roof
Old 10-17-2013, 09:54 AM   #4
kwikfishron's Avatar
Rewards Points: 90
There's no way to tell just from looking at that picture.
What's above it? What's below it? Is there a direct load path down to a concrete footing?
There's really no reason for a four 2x post for just a partition wall.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 10-17-2013, 10:00 AM   #5
cortell's Avatar
Rewards Points: 504
Excuse me for not reading you mind correctly. Kwikfishron nailed it.
Presumably so, given how many 2x4s are in column. Then again, it's offset from the ceiling gable peak. The definitive answer lies in what the column is attached to in the attic. If it's just fastened to a joist, then, no it's not load bearing. If it's supporting the ridge board/beam or a purlin, then yes--it probably is.
The Following 4 Users Say Thank You to cortell For This Useful Post:
GBrackins (10-17-2013), jclee (10-17-2013), Live_Oak (10-17-2013), woodworkbykirk (10-17-2013)
Old 10-17-2013, 03:09 PM   #6
Rewards Points: 274
I think it is not load bearing.
alexjoe is offline   Reply With Quote
Old 10-17-2013, 04:28 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
so it doesnt continue down in the basement?
if its not bearing. its simpoly laminated like that to make it stiffer to prevent deflection where its so long
woodworkbykirk is offline   Reply With Quote
Old 10-17-2013, 04:44 PM   #8
Registered User
Rewards Points: 4,924
Appear to be scissor trusses from the skylight shaft height......
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AndyGump (10-17-2013)
Old 10-17-2013, 05:35 PM   #9
Rewards Points: 626
Here is a easy way to find out rip it out and see what happens! about as accurate as asking on the internet.
Nailbags is offline   Reply With Quote
Old 10-17-2013, 05:56 PM   #10
GBrackins's Avatar
Rewards Points: 2,108
maybe more so ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-17-2013, 11:24 PM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Originally Posted by GBrackins View Post
maybe more so ....
Ha.
Beam for Load Bearing Wall jstein69 Building & Construction 3 02-17-2012 06:26 PM
Removing Kitchen Soffit - load bearing?? adrien2 Carpentry 4 09-25-2011 07:29 PM
Determining a Load Bearing Wall (Pic Included) Evil Scotsman General DIY Discussions 18 03-02-2011 03:46 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 10:23 PM
