Load On A 4x4 Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 03:40 PM   #1
load on a 4x4 post
4 x 4 redwood posts buried in dirt 2.5', 5.5' set above ground and are set at 8' apart with a playhouse built on top. How much weight can those 4x4 posts hold?
Stars2001 is offline   Reply With Quote
Old 10-08-2010, 05:05 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
How strong is the soil the post is bearing on? The post capacity is only one factor that can be reuced by the length/height, but if you are building on some clay or muck, that could determine the maximum load.
Dick
concretemasonry is offline   Reply With Quote
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 08:18 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
load bearing wall under king post trusses jimby Carpentry 5 01-02-2009 05:15 PM
