Living Room Foundation Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 01:51 AM   #1
living room foundation problem
on the outside wall of my living room at the floor there is a gap varying in width as it moves along the living room starting at quarter inch on up to prolly inch and a eight between the wall and the floor boards
from the outside you can kinda tell taht the bottom of the wall is bent out if you can get what I am saying its like that untill the wall and then the room right after it on the same outside room is perfect none of these problems
its a house built in the fiftees and it has solid wood walls behing paneling and asbestos cement tile on the outside
from the outside it looks as if the blocks sunk on the outside maybe putting pressure on the wall and bending them out im not really sure
this is due to im sure the gutters not being complete
they run with no downspout directly off the house and down on the ground where the water kinda made a trench and the water sits against the foundation
I will post some pictures tommrow but if anyone can help me it sure would be appreciated
thanks so much
rebelbull is offline   Reply With Quote
need new Living room layout, very confused fox_forma Interior Decorating 14 03-17-2010 08:26 AM
trailer in my living room (must read) wengang1 Remodeling 0 01-19-2010 03:30 PM
Red living room NewlywedKristin Interior Decorating 3 08-30-2009 10:45 AM
Skylight opening/portal through living room ceiling ControlTech Building & Construction 6 01-05-2009 07:33 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
