Lintel For Basement Egress Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 07:53 PM   #1
Lintel for basement egress window
What size lintel to use for 28"W x 52"H basement window in foundation wall that supports a 2-story light frame town home plus roof?
RWood is offline   Reply With Quote
Old 04-16-2011, 08:32 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
It all depends on the load and framing above (sill, bearing walls, etc.).
The 28x52 seems a little narrow for the rough opening for a legal egress window. The height of the window is not a real factor in the lintel sizing. First determine which window is certified as having an acceptable opening (not glass area) width and make sure the clear opening is in compliance with the local requirements (usually42" or 44" above the finished floor).
Dick
concretemasonry is online now   Reply With Quote
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 12:23 AM
egress window kikipauw Building & Construction 3 11-10-2010 06:30 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
