Lightweight Concrete As A Finished Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 10:49 PM   #1
lightweight concrete as a finished floor?
I've got a buddy that wants to pour lightweight concrete on his main floor and then acid stain it and seal it as a finished floor.
Does anyone know if this stuff is as hard as regular concrete? I was a little worried that it might not be very hard due to the composition of the product.
Also, does anyone know the difference in weight of this stuff and regular concrete. I don't even know the brand name. "Gypcrete" is ringing a bell but I have no idea if you can buy it at a local hardware store or not.
thanks boys.
the carpenter is offline   Reply With Quote
Old 09-26-2009, 10:58 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
there is a big difference between the soft, flimsy Gypcrete and real lightweight concrete than can be structural.
Dick
concretemasonry is offline   Reply With Quote
Old 09-27-2009, 07:31 AM   #3
Rewards Points: 4,534
pay attn to dick - fishing isn't the only thing he knows
you can substitute liteweight aggregates instead of crush'd trap rock or granite to provide a lighter weight conc,,, IF the support's avail for conc, a better solution's to install a cementitious polymer-modified overlay - much lighter per sf AND much easier to decorate/stain/sculpt/carve,, we have it in our family room but i do this stuff for a living.
gyp isn't a finish'd floor surface,,, you won't find anything at an apron store that a pro'd use no matter what the store people tell you.
Old 09-27-2009, 08:27 AM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
Concrete ~ 145 lb/cuf
LW Concrete ~ 115 lb/cuf
Gypsum Concrete ~ 105 lb/cuf
I wouldn't use nor specify nor install gypcrete as a finished floor, even if the customer asked me to do it.
Aggie67 is offline   Reply With Quote
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 05:41 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 03:36 PM
