-   -   Light on Suspended/Drop Ceiling Grid (http://www.diychatroom.com/f19/light-suspended-drop-ceiling-grid-168637/)
OhioDon 01-08-2013 10:16 PM
1 Attachment(s)
I want to put a light in my basement ceiling right where the clamp is located in the picture. That grid runs in the center of the room. I'm seeing two options:
1. Can I cut the grid and add some framing above to hang the grid on each end of the cut.
2. Use a plastic electrical box and notch the box to sit over the grid so the grid would end up basically running through the box.
Wildie 01-08-2013 11:19 PM
I would suggest removing the piece of T bar in question and then use a 2X4 tile with a hole cut for the electrical box!
joecaption 01-08-2013 11:39 PM
Or just move the light over.
OhioDon 01-09-2013 08:13 AM
I REALLY want to center the light across the room so I don't want to move it over but I might consider that.
Thanks for the idea of a 2 x 4 tile. I had not thought about that! But, that is a 48 inch "beam" there. Would I need to completely redo the grid around that? Could I just cut it off there and add a hanger wire at that junction?
