Lifting A Sliding Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 06:58 AM   #1
Stay-at-home GC
Lifting a sliding concrete slab
So our driveway is 8 concrete slabs approximately 12'x12' (its raining a real "goose drownder" out there so I'm not going out to measure it.)
They sit on a 30 degree slope. One of them is beginning to slide down the hill due to hydraulic subluxation or some other crazy term. Water and ice get under the slab, freeze, lift the slab slightly and away it goes.
Anyway, the slab that is sliding is beginning to push under the one below it.
Anyone ever used hydraulic jacks or cable rigging and turnbuckles to push/lift a slab up a hill?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-18-2011, 07:28 AM   #2
Rewards Points: 4,640
curious how long has this driveway been in place ? i'd have the soil checked out 1st,,, you might try a bodacious BIG crowbar, too
Old 05-18-2011, 08:10 AM   #3
Rewards Points: 5,336
It's like Plate Tectonics on a smaller scale. Watch out for earthquake activity associated with the uplift.
Ron
Old 05-18-2011, 09:50 AM   #4
Stay-at-home GC
Driveway has been in place 40 years. Very nice work. The rate of slide has accelerated because the lazy HO did not replace the fiber expansion strips when they rotted out 2 years ago.
Old 05-21-2011, 09:54 AM   #5
Stay-at-home GC
Hydraulic Flange Spreaders? Maybe.
Calculate the weight of the slab, plus the friction of the slab on it's gravel base. Use a grinder and some chisels to get a toe hold, then push up slowly. Chock it with pieces of brick as we go.
Once it's up. Cut some concrete brick to fit. Fill with appropriate sealant?
Best way to attach low level deck to existing concrete slab. fulghumd Building & Construction 4 03-11-2010 06:45 PM
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 09:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 10:57 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
