Lifting Hardipanels - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 08:14 PM   #1
Lifting Hardipanels
I've been re-siding a house with Hardiplank, and have gotten fairly competent ib the process. we are moving to another house this spring, and it's sided with T1-11 panels, many of which need replacing, so I thought I'd just go ahead and start using Sierra 8 HardiPanels. Of course, on the ends of the house I'll have 2 courses, so I'm looking for any tips or tricks anyone has discovered to lift these behemoths to the 2nd course. They weigh about 73 lbs per panel. Most of the 2nd course will not be full panels due to the roof line, but still, they're heavy!
My back thanks you!
Steve B.
Raleigh, NC
sebrame is offline   Reply With Quote
Shingles with Metal Plates Under Them Lifting? earthad1 Roofing/Siding 17 01-15-2010 12:57 PM
membrane lifting off side of roof Halli Roofing/Siding 2 01-30-2009 10:59 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Lifting from the outside cluksha Building & Construction 9 03-16-2008 03:52 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 11:53 AM
