Lifespan Of Galvanized Nails In PT Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 02:37 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Lifespan of galvanized nails in PT lumber
What is the lifespan of galvanized nails in pressure treated lumber?
I'm rebuilding my portico entry, largely using PT stock (rafters, posts, nailing 2-2x stock together, etc). Should I be concerned with the lifespan of the fasteners?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-30-2007, 02:48 PM   #2
Galvanized are what you should use, they are supposed to last forever (not sure how long that is).
warnerww is offline   Reply With Quote
Old 07-30-2007, 03:12 PM   #3
Agent 000
SecretSquirrel's Avatar
I'd be more concerned with the lifespan of the PTL.
From the Maze nail web site;
Maze STORMGUARD galvanized nails have passed the ultimate test with flying colors over 85 years of field service with a record unmatched by any other zinc-coated nail producer.
For your reading pleasure:
http://www.mazenails.com/hdgspecs.php
SecretSquirrel is offline   Reply With Quote
Old 07-30-2007, 03:36 PM   #4
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
YES!
Vendors that do not have the inventory dollars to stock stainless will tell you that galvy is fine and not to worry. Spend some time on google researching the topic before wasting your time and money.
my 2 cents
fhivinylwindows is offline   Reply With Quote
Old 07-30-2007, 04:25 PM   #5
Ok I know I said galvies will last forever (I have never seen them fail but I do live in a dessert climate). Stainless will last and last also. I hate driving them though because they are so soft the things really like to bend.
Old 07-30-2007, 04:36 PM   #6
I have gas!
The new PT stock has only been out for 4 years, that's why I'm wondering about the new heavier coated galvanized nails.
I read someplace that the galvanized nails should outlast the service life of a deck, but realistically, what's that, maybe 20-25 years?
Old 07-30-2007, 04:49 PM   #7
Depending on where you live and what you use decks can last a long time. I fully expect my decks I built on my house to last 50 or more years. I used pt everywhere went down 2 feet with sona tubes and used composite decking. So far it has been only 12 years but they look as good as the day I built them. I will let you know in another 38 years if my expectations worked out for me.
Old 07-30-2007, 05:02 PM   #8
concretemasonry's Avatar
Rewards Points: 2,578
It only takes a scratch or chip in the galvanizing to make it like a normal nail in short order.
That is the reason for the failures of galavanized screws in steel studs if moisture is present.
concretemasonry is online now   Reply With Quote
Old 07-30-2007, 05:05 PM   #9
fhi vinyl windows
Rewards Points: 150
http://www.strongtie.com/ftp/catalog...-p010-p011.pdf
Old 07-30-2007, 05:16 PM   #10
Rewards Points: 1,910
Warnerww - you probably used CCA 12 years ago. This new ACQ is highly corrosive. In an outdoor environment I wouldn't expect galvanized fasteners to last 12 years in ACQ. But I can be a pessimist.
For a drier, enclosed area like rafters they might but I'm not sure why you'd use pressure treated there.
Old 07-30-2007, 05:24 PM   #11
robertcdf's Avatar
Just go stainless steel and be done with it.
robertcdf is offline   Reply With Quote
Old 07-30-2007, 06:21 PM   #12
I have gas!
hmmm, did I make a mistake by buying PT for this project? I was trying to protect the rafter tails from rot so I thought PT would be the best choice. Then I thought what the hell, I might as well use PT for everything.
I don't have much assembled yet, do you think I should I build it with standard lumber?
Old 07-30-2007, 06:42 PM   #13
Union HVAC Tech.
Stay with the PT lumber just use stainless nails. In my area near the ocean galvanized (hot dipped better than plated) just don't last.
bigMikeB is offline   Reply With Quote
Old 07-30-2007, 07:01 PM   #14
Well that sucks. Just helped a buddy build his deck (used galvies). Will find out how it holds up in about 10 years. So this new and improved stuff will not eat stainless Nails (did I mention I hate stainless nails)?
Old 07-30-2007, 07:13 PM   #15
fhi vinyl windows
Rewards Points: 150
Take a few extra ones and nail them into some scrape 4x4's and pull one out every 6 months and see what the difference is. I have some pictures of 1/2 lag bolts that are eaten away to the size of a pencil---I will scan and post them when I find them again.
Siding Nails Clutchcargo Carpentry 20 06-16-2007 05:33 PM
Rusting nails on exterior firsthomegal Painting 7 05-28-2007 06:15 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
