Old 09-04-2009, 09:44 AM   #1
Leveling a VERY uneven basement floor
My basement floor is very uneven -- the centre is as much as 6" higher than the outside. It was recommended that I use concrete poured in on top of the existing (cracked) slab. Is this the best bet? Will I have to do more than one pour? Would sleepers be an option? (With sleepers I could insulate under the subfloor, which is desirable as I'm in a cold region of Canada.) Thoughts? Thanks so much!
cbeingessner is offline   Reply With Quote
Old 09-04-2009, 10:54 PM   #2
Six inches is a very big descrepancy for a floor. Depending on the shape of this mound, I would probably jack hammer the middle, out towards the edge so it was more or less level. Then pour the middle and float it level to the floor that was left. The remaining height difference could then be addressed with a leveling product.
Ron
Tags
basement, level floor, uneven floor
Wet basement floor Saiboogu Building & Construction 9 08-12-2009 06:19 PM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 02:39 PM
basement floor not level rjstallings Flooring 2 02-12-2007 03:29 PM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 03:11 PM
