Leveling Floors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 12:37 PM   #1
leveling floors
Does anyone have an easy way to check if main beam is level in crawlspace i have a fairly new home 26x 70 ranch 2x12 joists in 16 centers with main carry beam is 4 2x12 nailed together( with 2 inch side being on top and bottom ) there are concrete peire every 8 foot with 8x12 concrete blocks stacked to bottom of beam and shimmed with oak boards , I want to see if it is running level down the whole house .any ideas thanks for your help
glorybound32000 is offline   Reply With Quote
Old 12-03-2010, 12:45 PM   #2
you can use a string line and three spacers, but I'd get a cheap laser and set that up. Measure from the laser beam to the top of the beam at every point the beam is supported. Take notes of the measurements at each point you check.
mrgins is offline   Reply With Quote
Old 12-03-2010, 12:48 PM   #3
The beam supports should be on a concrete pad. They should be adjustable steel posts or lally columns cut to fit with metal plates to and bottom
Old 12-03-2010, 12:53 PM   #4
Civil Engineer
Rewards Points: 4,700
The laser works well if it can be set up and seen. If that is not possible, you can make accurate measurements using a fluid level. I have one made by the Zip Corporation, it is accurate to about 1/8 inch. I believe they can be rented.
Old 12-03-2010, 02:06 PM   #5
floor leveling
Is that the same kind of laser they use for like suspended ceilings it spins and leaves line around the room,thann measure down what the 11 7/8 set laser or what thanks for the help ,i have a very deep crawl from bottom of joist to ground approx 48 in or so
Old 12-03-2010, 02:30 PM   #6
Rewards Points: 80
I feel sort of silly suggesting this, based on the other suggestions (not that there is anything at all wrong with them), but unless I had cracked drywall, or something else that indicated a problem, I would just take a 4' or 8' level, a tape measure, pencil, and paper down there first. Check between each set of piers, and if it's anything other than center of the bubble, jot down how much it is off, and compare your notes when you are done. Then, if you see a concern, buy a water level, or rent a laser.
Old 12-03-2010, 07:17 PM   #7
There's all kinds of lasers. I have a PL300 which just gives straight lines. More accurate/reliable than a level or a water level
Old 12-04-2010, 10:13 AM   #8
leveling floors
Thanks for all the help i will try bubble level first ,I will also take the advise and replace blocks with jacks post that will make leveling easier, this all came about becase i seen blocks cracking and contractor came back and replaces but i think he has that area a little high thanks agian
Leveling floors in an old house cassandchris Flooring 2 11-05-2010 09:13 PM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 06:50 PM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 11:11 AM
