Leveling A Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 09:07 AM   #1
leveling a floor
We have an older split level home. We are looking to add more space in our lower level, which is not fully under ground - it's about half under and half above ground.
Both of the rooms have drains in them and the floors are painted. We want to level the floors, but I have a concern with pouring concrete with the floors being painted. I don't want to level out the floors only to have the concrete not bond to the painted floors
Any suggestions?
psrs0810 is offline   Reply With Quote
Old 08-15-2010, 11:57 AM   #2
Rewards Points: 5,336
Self leveling compounds include a primer that is applied to the surface so bonding occurs. Check the manufacturer you're using to see if the installation you have will work with their product.
Ron
Pitched floor leveling issues. uberdoom Flooring 0 07-19-2010 01:47 AM
Leveling floor for use with Platon dstylez Flooring 0 01-17-2010 01:30 AM
floor leveling compound geraldS Flooring 4 03-01-2009 08:20 AM
Leveling floor for Neo-shower base mrfixit821 Flooring 6 11-28-2008 04:26 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
