Leveling A Floor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 12:29 AM   #1
Leveling a floor.
I'm leveling a 2' x 3' area by 3/16's of an inch and the leveling mix I'm using says to put a screen down, but I don't think it's necessary for that depth.
To use or not to use? Answers appreciated.
Jwindsor is offline   Reply With Quote
Old 10-27-2011, 05:43 AM   #2
DIY staff
Rewards Points: 7,174
More info--what kind of floor what type of leveler?
Generally speaking---no mesh is used or needed--Mike---
Old 10-27-2011, 01:31 PM   #3
I'm putting it over plywood and the name of the mix is Level Quik.
Old 10-27-2011, 02:59 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Level Quick does not require a screen in this application. Just be sure to use the realted primer, don't forget that, it's important.
That application will take less than a half of a bag, so adjust your material and water accordingly.
Old 10-27-2011, 08:26 PM   #5
Leveling a floor
I put the Level Quik Latex Primer on this morning after cleaning and removing any dust that was on the floor, so now I'm going to pour the leveler on tonight. Thanks for your advise.
The Following User Says Thank You to Jwindsor For This Useful Post:
Bud Cline (10-27-2011)
Old 10-27-2011, 08:38 PM   #6
DIY staff
Make sure that you have sealed any holes or cracks---that stuff will flow through some small openings--
self leveling a floor BlueBSH Building & Construction 4 01-20-2011 10:01 AM
Pitched floor leveling issues. uberdoom Flooring 0 07-19-2010 02:47 AM
floor leveling compound geraldS Flooring 4 03-01-2009 09:20 AM
Leveling floor for Neo-shower base mrfixit821 Flooring 6 11-28-2008 05:26 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
