Leveling An Existing Interlocking Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 05:08 PM   #1
Leveling an existing interlocking wall
I have an interlocking concrete block wall, installed about six years ago. An area has sunk about eight inches. Is there any way to level the wall without taking the whole thing apart??
dabob is offline   Reply With Quote
Old 05-02-2009, 05:19 PM   #2
Old School
Willie T's Avatar
Not really.
Willie T
Old 05-02-2009, 06:12 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
Whoever built the wall did not prepare a proper base. You have no way to tell what will happen in the future.
You do not have to tear down the entire wall but do a stair step down to the sunken area of the base material. Dig out the soft base and replace with a compacted base that is level and then rebuild the wall with units you reomved. - They will match.
A common problem with a lack of proper preparation that comes with all retaining wall types. It is good it was not a poured or rigid wall that had a poor base and footing.
Dick
concretemasonry is online now   Reply With Quote
Tags
concrete block wall
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Replacing existing wall with support beam or I beam sourdough Building & Construction 4 08-06-2008 09:42 AM
existing CMU Shear Wall g8rdd Remodeling 2 03-22-2008 04:08 PM
add a shed roof to existing wall gcreek Roofing/Siding 2 03-10-2008 09:19 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
