Leveling a concrete slab floor
The floor is out of level fro 0-3 inches over an area of about 800 sq ft. The cost of self leveling coumpounds is astronomical over $15k we would like to use mortar and level it section at a time to save cost. We have good manpower just not lots of money. What are your recomendations?
There are few options in this situation. Because you have a 3" difference any self leveling compound is cost prohibitive. That leaves removing the existing slab and repouring or pouring on top of the existing slab.
Repouring is better, but more expensive. Pouring on top has many pitfalls too. Tell us more about the characteristics of the site. |
Did you know you can add pea gravel to Self Levelling Compounds thereby increasing the cubic foot volume per bag and reducing the cost by almost half?:wink:
You could also order a mix of sand and Portland from a local Redi Mix plant (it is also called grout but it isn't like ceramic tile grout.) Use it for filler to raise the lower side in range with the higher side, then finish it off with Self Levelling Compound.:yes: |
| All times are GMT -4. The time now is 08:23 PM. |
