Leveling Concrete Around A Bathroom Floor Drain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 09:35 AM   #1
Rewards Points: 1,062
Question
leveling concrete around a bathroom floor drain
does concrete surface around a floor drain (unusual for residential applications, at least as far as i have seen, but sure as hell makes mopping easier) in a basement bathroom need to be mildly sloped towards the drain WHEN FINISHING THE CONCRETE or can this be done when setting tiles somehow ? or does it need to be done at all as water will somehow flow towards it without gravity (yeah right) ?
Old 01-17-2008, 09:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,082
does concrete surface around a floor drain in a basement bathroom need to be mildly sloped towards the drain WHEN FINISHING THE CONCRETE
Yes.........
Bondo is online now   Reply With Quote
Old 01-17-2008, 10:03 AM   #3
too late, already finished it flat. any recommendations ? would grinding it with a 4.25 in grinder and a masonry blade do ?
Old 01-17-2008, 10:25 AM   #4
i think that the adverse effect of the mistake will not be so drastic as it will be used just for draining mop water (and not e.g. showering). the excess can be always manually directed towards the hole.
Old 01-17-2008, 01:32 PM   #5
some bathroom don't even have a drain hole.... so I think your levelling floor is ok and not to worry.... levelling floor infact is a good thing for tiling later on in your project.... don't "dislevel" it now....
a drain hole only requires for code I believe to avoid flooding in basement... but generally not being used otherwise....
KUIPORNG is offline   Reply With Quote
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 05:37 AM
leveling concrete floor Cyrus Flooring 5 10-15-2007 03:26 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 09:31 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
